Rear LCA ????>>>
Rear LCA ????>>>
<center><img src="http://www.ttstuff.com/images/forge/FMPFR3510_540.jpg"></center><p>Is this the correct bushing that Al @CPT recommended changing out when installing the lca??
Thanks<ul><li><a href="http://www.ttstuff.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=FMPFR3510 ">http://www.ttstuff.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=FMPFR3510 </a</li></ul>
No. That bushing is a part of the new control arms. It's the outer bushings that he suggested.
The outer bushings (spherical bearing on 2000-2002 and rubber bushing on 2003&later)is the one that seized on SparTTan and broke his control arm.
ECS tuning carries them.
Re: can you link me to the correct part? Thanks
Look at the outer rear upper and lower ball joint. IT's available in two flavors ES#4198, Pre 2003 sphereical bearing (expensive) and 2003 - rubber bushings (relatively cheap) ES#4627.
Dan<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&engine=225HP&mo del=TT%20MKI&submodel=Quattro&category=Sus pension">ECS Tuning</a></li></ul>
ECS Tuning-Audi
A4 (B8 Platform) Discussion
01-23-2018 08:43 AM
ECS Tuning-Audi
Audi A3 / S3 / RS 3
04-27-2016 11:29 AM
Jeff Vader - boscoj
12-17-2002 01:02 PM
