Regarding 40K maintenance - Haldex, plugs, and filters are going to be done. Anything else??
This is my last Warranty maintenance, if there is anything else I could get done, please let me know.
This is the list I found and used (Sorry - I don't know who posted it originally)
At 40,000 Mi (64,000 Km)
Engine Oil - Change the oil.
Engine Oil Filter - Replace the oil filter.
Engine - Check for leaks.
Cooling System - Check the coolant level. Add coolant if necessary.
Exhaust System - Check for damage and leaks.
Engine, On-Board Diagnostic - Check Diagnostic Trouble Code Memory. Purge if necessary,
where applicable.
Doors - Lubricate door hinge mechanism.
Battery - Check electrolyte level. Add if necessary.
Windshield Wiper and Washer - Check fluid level. Add fluid if necessary.
Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation.
Tires and Spare Wheel - Check for wear and damage. Check the pressure.
Service Reminder Indicator Display - Reset the display.
Brake system - Check for damage and leaks. Check thickness of pads and brake fluid level.
Drive Shafts - Check the boots.
Road Test - Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning and power accessories.
Lights - Check the lights.
Front Axle - Check dust seals on ball joints and tie rod ends. Check tie rods.
Haldex Clutch - Change oil and filter.
Power Steering Fluid - Check fluid level. Add if necessary.
Dust and Pollen Filter - Replace filter.
Headlights - Inspect headlights. Adjust if necessary.
Air Cleaner - Replace filter element.
Spark Plugs - Replace the plugs.
where applicable.
My dealer didn't do the Haldex at 20K - BUT NOW, I just called
and asked them about each item. They said O.K. ..Hmmmm... Since they didn't follow the list at 20K, they probably won't again. But at least I know what to ask for, and what to check for.
I will give you an idea of what was done to my wifes A6>>>
they replaced the rear pads and cut the rotors back in jan cause the rotors were warped! Back in Oct the car was in for rear pads....last thurs, my wife calls me to tell me the A6 is running crappy...CEL on...turns out its a coil pack...and then i am told they replaced the brake fluid, as it was time for it..20k mile service...
Car was in for its 20k back in Jan...and now its got 21k+ on it...so what was done then??? Not to mention the service in late Jan that was done, they replaced the Front brakes cause the sensor just came on....why were ALL of the brakes not checked back in Oct you ask??? Well, Audi only addresses "the problem" and does no proactive work was the answer i got. So the customer is inconvenienced by multiple visits??? on a safety item???
I do not believe its the dealership..just Audi and their crappy policies and warranties....just my rant!
