Regrading my DV
Regrading my DV
This post is 2 parts...
Part I) Should I use any special sort of grease when greasing my DV? Lithium grease okay?
Part Deux) Since I put my TIP in, when I hit high boost (25 PSI or so) my cats stutters a lot (not all the time, maybe 1/4 of the time or so). Could this be due to too weak of a spring in my DV?
PS - I'm going to lower my boost soon, I'm waiting for my OBDII cable in the mail, when I get it I'm going to lower it with Lemmiwinks, so hopefully that will get rid of this problem...
what software are you running?
25psi sounds awfully high...i don't know why your car would 'stutter'...could you explain what happens??
you should use synthetic grease (available at any parts store) for your dv
Revo...it's only 20-21 PSI w/ the stock N75 but it's around 25 w/ the N75J >>>
It will boost and get up to the mid 20's just fine, but when it tries to hold there it kind of...shakes? Like it wants to pull, and it will, but not consistantly...doesn't feel at all like a boost leak though.
bushido
06-25-2007 06:01 PM
