replacing strut bushings/bearings with KW v.3s...is there a special tool for the center
part? i have a tool to remove the large nut below...but what do you use for the top part to keep it from spinning? i tried all kind of sockets and nothing fits over, since its got a flat sides for an open wrench, but i can't get the open wrench in there...its too deep.
any suggestions? this is for KW v.3 with adjustment on top.
You need this.....
<center><img src="http://zdmak.com/wbstore/images/NW3077.jpg"></center><p>i've tried deep offset wrenchs and 02 sockets - and nothing works. Impact gun will work as well - but you need this special tool as its open enough to allow you to put a full 10 mm wrench inside it.<ul><li><a href="http://zdmak.com/wbstore/main.asp?action=PROD&PROD=MK-4491AA&CTMP=1">Special Socket</a></li></ul>
