REPOST: My question on the boost gauge was deleted for some reason . . . why???
Anyway, here is the question once again:
What is your boost gauge reading at idle? I originally said mine was 20" Hg, but I rechecked it tonight. While warming up the gauge is showing 10-15" and once warm it settles in at 24" Hg or vacuum.
I live at the ocean. I have a 180TTQ with a Garrett Stage II chip and Borla exhaust.
That's kinda odd..
Your car changes 9 - 14" of Hg when warming up? On the 10-15 measurement that you state, was your compressor on?
On my stage 3 A4, I get this:
Cold idle (no AC): 18/19
Cold idle (AC): 17
Warm idle (no AC): 19/20
Warm idle (AC): 17.5
Two things to note: Relatively small change when running the compressor, and also again a very small change from cold to warm idle.
Most vacuum I see is 24" Hg on trailing edge throttle. Most boost I've seen is 25 psi.
S.
Cold idle (AC): 17
S.
18 to 19 is perfectly normal for a spike.
I'd personally be a little wary though if it was holding that much boost throughout the RPM band.
I'm not really sure, but 180's have a K03 turbo, right?
S.
S.
ModifiedA4
11-19-2007 06:51 PM
PanTTher
07-04-2004 02:39 PM
