So here are my sub install instructions: (new method)
1: Run power wire ( youre on your own for this one)
2: Remove the lower section of the rear seat (there are 2 plastic clips on either side)
3:
<img src="http://pictureposter.audiworld.com/73987/sub_001.jpg">
**This is on the passanger side**
4:
<img src="http://pictureposter.audiworld.com/73987/sub_002.jpg">
5: this leaves you a very easy method to run the rest of the wires. Finding a switched 12v isnt easy (the one on the back of the head unit doesnt work?)
3:
4:
more questions...
did you remove the subwoofers or setup the crossover on the new amp to just be a lower frequency than them?
also why not tap into both left and right rear speakers? or before the amp...
I'm not sure but I would be led to believe that if you tap after the amp you are going to get a worse signal than just the headunit? maybe considered a more conditioned signal...
with the bose system you have to tap after the amp...(+)
i tried to tap before it and that didnt work at all. The rear speakers in a TT are both just fed low frequency bass (which actually works out well), and in that case a mono signal is cleaner sounding.
aargyle
A4 (B7 Platform) Discussion
04-28-2010 08:29 AM
RippleChip
11
04-28-2004 04:34 PM
Chard
08-09-2002 09:48 AM
Chard
08-09-2002 08:18 AM
