software upgrade?
Old Mar 21, 2005 | 06:00 AM
unc99206's Avatar
Member
Default software upgrade?
wondering on the timing of getting the "chip" put in my car. i was not sure how the chip would react with other upgrades. such as FMIC and some modshack parts and possibly injectors(still debating). will it need to be updated after these parts are installed to achieve max efficiency/ performance, or does the chip update itself? is it better to wait till after more mods are in to have the chip installed?
Old Mar 21, 2005 | 06:10 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Car will adapt to a certain point...>>
Mods tend to improve efficiencies and power. Sensors get bettter numbers and tell the ECU everything's OK. ECU then ups potential performance parameters...Timing, fueling maps, etc.
Basically doesn't matter when you chip. The mods you mention will maximize the benefits..
Old Mar 21, 2005 | 06:13 AM
TTGram's Avatar
Member
Default Re: software upgrade?
Chip will have no problem dealing with FMIC. Modshack parts are minor and computer can deal with them. Injectors may need a reprogram of the chip.
Old Mar 21, 2005 | 06:20 AM
unc99206's Avatar
Member
Default Re: Car will adapt to a certain point...>>
so there would be no need to retune after doing all of that stuff?
Old Mar 21, 2005 | 06:49 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default No......>
Car will adjust itself....
For instance, FMIC will result in a lower temp being recognized at the manifold temp sensor. This provides major input to the ECU. Lower temps means more timing can be advanced.
TTDA, Better air flow, higher MAF signal...ECU will adapt fueling to the new reality via that signal and the downstream 02 readings...
Once chipped, there's nothing really you can "Tune" except to optimize all the inputs.
Old Mar 21, 2005 | 07:19 AM
unc99206's Avatar
Member
Default chip goin in then i guess
so i should probably jus go ahead and do that then...thanks for the input
Old Mar 21, 2005 | 08:37 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default Might want to tighten up that turbo intake hose, though. Otherwise you may run lean if you leak in
after the MAF.
Old Mar 21, 2005 | 09:11 AM
unc99206's Avatar
Member
Default last clamp
i'm gonna put that clamp on one of these days, i just had to get the car running so i could use it. i hooked it up to the VAG and no leaks showed so...for now its aight, i;'m gonna put the clamp on, should be good for now though right? its not jus gonna fall off i hope. any recommendations on how to get that clamp on?
Old Mar 21, 2005 | 09:25 AM
Tech Guru
Default I would not bet that it won't fall off. MarTT's hose came off very easily...
Others have reported how easy theirs came off as well. I don't see any way to put a new clamp on without diassembling everything again. The hose either has to come back off to slip on the clamp, or you have to loop a clamp over the end with the hose still mounted... Given the limited access, I don't see the "slip over" option as a real choice. It took me an hour to get my clamp on, but that beats 4 hours to take everything apart again!
Old Mar 21, 2005 | 09:49 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default That's pretty foolish...>>
Actually VERY foolish. A VAG isn't gonna show a leak there. You are definitely running the risk of burning lean from any leakage.
The consequences of that are pretty big ($$$ wise)
The clamp is not THAT tough to get on...
Reach down there with your left hand, a stubby ratchet and a 7mm socket. Tighten it. That's it. As mike pointed out though, sine the clamp is not even on the hose, you're gona have to pop it off again to slip the clamp on.....
