some one here had posted a pic of some welding support for the 42 DD down pipe. cant find it. help?
You might be thinking of this one, easy search......................
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1814803.phtml">https://forums.audiworld.com/tt/msgs/1814803.phtml</a</li></ul>
Junior Member
i think there is a lot of stress where it connects to the turbo.
hangs from that gray rubber hanger to the turbo!!! and i think i hear it rattling around the flex area
the cat back has beeen modified for a better fit.. and that band is there because they installed it a bit crooked and it hits the side. they will fix it this weekend.
..yes that resonator is very close to the ground its scary
<img src="http://pictureposter.audiworld.com/149147/dscn3697.jpg">
<img src="http://pictureposter.audiworld.com/149147/dscn3723.jpg">
<img src="http://pictureposter.audiworld.com/149147/dscn3704.jpg">
I've had a 42 DD DP now for longer than anyone here & I'm sure it's cracked or loose again
It started about a month ago after three straight long track days. It came completely loose before and I used metal locknuts to secure it - I've checked all connections and all bolts appear tight - at least on the lower section and at the turbo. I've even replaced all my motor mounts including the dogobone with a new track density mount which is stiffer than the stock with poly's and it's still rattling and clunking.
Either my turbo is loose, manifold is loose, or DP is loose or cracked - but somethings failed. It's really hard to see what is wrong - but all the bolts I can get a wrench/socket on appear to be tight. I'm sure it's because it's not adequately supported. Stasis warned me about this during the install and i've been meaning to put the additional bracing on - but didn't have a chance.
SilverCQ
06-27-2005 01:12 PM
MarkN
08-29-2002 03:25 AM
tb1200 - word up doc
08-19-2002 12:27 PM
CEEZZ
05-02-2002 11:43 AM
