Started using 89 Oct gas? Am I hurting my TT?
I have a 01' 180FWD Coupe. I recently swithced to using 89 Octane (at 4000 miles) as the 93 in the area I was in was just too expensive. Car seemed to run fine, very peppy, no pinging noises or anything. As long as it seems okay, what other "hidden" harm might I be doing to the car? I assume the ECU will adapt to the lower octane and adjust the timing accordingly. Thanks for the help.
Jon W.
Jon W.
Yep - It will detune.
Turbochargers have "ping" sensors. A "ping" will blow out the turbo. SO they do modify the timing to eliminate the "ping".
But the real question is why are you happy with less power? We buy the car for the great combo of styling and performance!
89 may not be a problem...
For the 180. But a less than reputable gas station that sells 86 octane labeled 89 will be.
Midgrade of ~91 may be a good compromise.
Usually a dishonest gas station will sell 89 octane instead of midgrade, still leaving you a margin of safety.
you spend, what, $40k on a car and then gas is too expensive?
$1.95 a gallon here for 91 octane. Save money somewhere else, do your car a favor. they don't require 91 octane because it's a conspiricy with the gas companies, they require it as to not destroy the engine/fuel system.
