Strange Behavior
Anyone ever have trouble with the window auto-up/auto-down feature?
For me, the problems occurs after I have simultaneously used the auto-down feature on both windows. When I attempt to put the windows back up with the auto-up feature, the windows begin to close, but close to completing their upward travel, one of the two windows stops and begins to go back down, part way. Once this occurs, the auto-up feature no longer works and I have to hold the button in the up position to completely close the window. Once both windows are closed, however, I am able to use the auto-up/auto-down feature again till the process repeats itself, approximately 50% of the time. Of course, when I pointed it out to the dealer service, the problem ceased to exist. The dealer has a plausible theory. The thickness of the window tint is activating the "pinch protection" feature, causing the window to go back down. Can anyone else support or debunk this theory with their TT experiences? |
do a search
there is a trick to reset the windows
it seems to be somewhat common |
Dealer is BS. Happened on my car, NO tint, after changing the battery.>>>
Happened twice, both on different drives ( i.e. the car was shutoff and sat in between occurences, ) but it hasn't happened since ( at least 1.5 months. )
TT electrical gremlins. |
Great Thanks!
<ul><li><a href="http://search.audiworld.com/index.mhtml?q=reset%20windows&wf=022210&m= all&cat=010209&dt=range&db=01/01/1999&de=05/11/2004">http://search.audiworld.com/index.mhtml?q=reset%20windows&wf=022210&m= all&
Bwahaha....Most creative dealer excuse of the day!
That happens. Just reset and go on with life..
Actually....
Depending... you might want to use some window tint spray on your tints.. it contains silicone, and they won't "grip" as much against the rubber. It can technically happen.
It can also be the adjustment of the window. |
I live with "BUGS" everyday...But Ilive in TX>>
You can chase them and swat them if you wish..They will always come back.
uuuuuuuhBBB*hitttt!!!
Had the same problem this week. Thanks for the link.
yes i had the same problem
i took it to the dealer and of course the windows work fine. SO they reset it and sprayed slicion into the channel of the windows and it seemms to be working well for me.
