Stupid question about adjustable DV's
On adjustable DV, in regular orientation, does increasing the tension of the spring make a difference on how much boost you can hold?
This seems to be the case in reverse orientation (for obvious reasons) but i'm skeptical about regular orientations.
Any thoughts? Thanks!
It really doesn't matter...>>
Boost coming in the top and bottom tend to equalze each other....The spring Preload has less of an effect than you might think...but it does help you tune the car for best settings..
Thanks Steve!
Your description is for a reversed (boost to piston, n249->nipple) config, right?
What if you are going regular orientation? Does springload make any changes there?
Blue TTop
11-28-2004 03:46 PM
