subframe bolt missing...hence the creaking...
i just noticed today while changing oil that 2 bolts are missing from the subframe(# 4 on the picture; picture from a previous post by TTschwing/Modshack,thanks). does anyone know where i can get replacements and maybe what the part numbers are?...i hope someone can help.....thank you ahead of time.....
<a href="http://www.flickr.com/photos/71467439@N00/2984824529/"><img src="http://farm4.static.flickr.com/3226/2984824529_1b69779e20_o.gif" alt="subframe" /></a>
Those things...
are supposed to be torqued to 75 lb-ft plus 1/4 turn. You need serious leverage to do that, and there's no way they could work loose. There was some work done to your car at one time, and they weren't torqued properly.
Those are torque-to-yield bolts, and are only good for one time use. Replacements from the dealer, or your favorite genuine VW parts internet store.
Re: the dealer.......>>>>>>
thank you for the help....after scouring the forum i finally found the part number...i read so many posts i forgot from where in the forum i got it from....no matter...here's the p/n (N90752801)just in case someone else might need it...please correct me if i got the number wrong..and here's a link to where i plan to get the part from.....thank you again...<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?searchstring=90752801&searchq t=byvehicle&make=Audi&model=TT+MKI&sub model=FWD&engine=180HP">http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?searchstring=907
I know that the subframe bolts are listed as one use but-------->
Mine have been out and back at least twice, wonder what the risk of breakage is? Someone------ Schwing????? has stated here that it did not seem imperative that they be replaced each time. Opinions??? Facts ???? TIA.
I have heard that torque-to-yield bolts typically have enough stretch in them to
be suitable for a few uses.... the bolts on my engine mounts were reused after my timing belt replacement at 57k miles... I now have about 100K on the TT and no problems. However, next timing belt replacement, I'll probably install new bolts.
audi2.7audi
01-15-2007 04:39 PM
cuatrokoop
01-22-2004 04:23 PM
PhilMason
14
07-19-2002 12:40 PM
