Temperature gauge update...
I took the advice here and checked the HVAC temps while driving. Even though the temp gauge runs at 1 tick above center it never got over 84c on the HVAC panel. I could have sworn that my temp gauge was always at the center while driving before. If I'm reading into this correctly it sounds like the cluster? Your input is always appreciated.
Ignore one tick, especially if the HVC says it's ok.
Mine does the same after my TB change. Unless other items on your cluster are also way off, including missing pixels, I wouldn't worry about it. Most bad clusters reported here have huge disparities between fuel reading on the gauge and the analog dial and miles to go readings.
nikhil
14
08-15-2005 12:20 PM
