Thanks to those that answered Headlight Questions.
<center><img src="http://i131.photobucket.com/albums/p312/diehlryan/headlightinstall.jpg"></center><p>Was able to order from ebay and it arrived today. Took about 90mins to install. Couldn't get the bumper cover loose. The p/s wheel well liner wouldn't come off. 1 torx screw was just not letting go. Therefore I couldn't loosen the 10mm bolts.
Anyways wedged the headlight in and got everything aligned. Nice to see my car without a "blackeye."
Although it looks like the d/s could use some adjustment.
Thanks again.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1606771.phtml">Original Thread</a></li></ul>
Once that nose comes off the first time...
you can never get it aligned 'quite' like it should be again. At least I haven't been able to, and I've had my front off three or four times in two years. Anyway, glad you got your headlight fixed.
PS. Getting the nose off is much harder when you still have SMIC's.
Or...
jackstands.
I did the work with the tires still on the car obviously still on the ground. Won't make that mistake again. I was too excited to get the headlight in and I couldn't wait for the weekend to get to PA where my stands are.
Gingerbread man
06-30-2004 06:49 AM
