is there a block or pan heater available for the AMU engine?
Old 02-19-2007, 05:59 AM
adminisTerTurbo's Avatar
Default is there a block or pan heater available for the AMU engine?
brrrrr
Old 02-19-2007, 06:09 AM
Member
stilljester's Avatar
Sure - I'd use the type that mounts in a core plug hole. Webasto is the brand I've used in the past
Old 02-19-2007, 06:22 AM
JustJeff's Avatar
Water 'tank' heaters are generallly more effecitve, but they may be hard to find.
Old 02-19-2007, 06:25 AM
AkRascal's Avatar
Default Silicone heaters are easy to install and work well
<ul><li><a href="http://www.jcwhitney.com/webapp/wcs/stores/servlet/Product?storeId=10101&amp;Pr=p_Product.CATENTRY_ID %3A2005253&amp;TID=100&amp;TID=100&amp;productId=2 005253&amp;catalogId=10101">http://www.jcwhitney.com/webapp/wcs/stores/servlet/Pro
Old 02-19-2007, 06:32 AM
AkRascal's Avatar
Also found them on eBay do a search for "silicone hot pad"
Old 02-19-2007, 07:46 AM
JustJeff's Avatar
Default Wow, wish they had that when I was, um, "younger". Can't tell you how many block and tank heaters...
I've installed.
Old 02-19-2007, 07:57 AM
Default looks like a very viable option
i just worry about it retaining heat in the summer...at the track. looks like it might be easily enough removable.
Old 02-19-2007, 08:05 AM
Scenic Driver's Avatar
Default Another source here >>
<ul><li><a href="http://www.arctic-fox.com/">http://www.arctic-fox.com/</a</li></ul>
phuynh
Q7 MK 1 Discussion
07-02-2015 04:53 AM
Y2KS4
03-16-2010 11:49 AM
Kenneth_h
Audi 100 / A6 (C4 Platform)
13
03-25-2008 03:55 PM
ColoQuattro
12-31-2004 04:28 PM
FixedWing
01-11-2004 06:09 PM
Quick Reply: is there a block or pan heater available for the AMU engine?
