Is there a difference between the Forge and Bailey DV's besides cosmetics?
Also has anyone tried both and got different results. I have the Forged right now and not so sure it is performing up to par, and i do have the upgraded piston.
Both are good valves... Bailey is permanently sealed...
and has the plastic-sort-of piston. As you know, Forge is serviceable and now has the aluminum piston. Forge seems more solid in operation to me-- just my opinion, but I have run both valves for over 6K miles each.
What problems are you having? Might be time to disassemble your valve and inspect/re-lube.
Lots of bogging in low rpms, sometimes turbo will kick in and then just lost power until I shift to
another gear. I put the stock one back in this morning and seems to be a bit more smooth than the forged. However, not a strong a pull with the stock DV
Get one of these. They work and keep working because of the design.
<center><img src="http://pictureposter.audiworld.com/20566/turboxs_flow_orientation_copy.jpg"></center><p>
<ul><li><a href="http://www.racetep.com/xsrhbv.html">Turbo XS Racing Bypass Valve</a></li></ul>
Hyperspeed--
03-01-2004 04:28 PM
duffman1101
10-15-2003 12:25 PM
RuS4
12
08-01-2001 11:19 AM
WJM
04-04-2001 09:19 AM
