think this is bad?
think this is bad?
i removed my rear left axle but it was kind of stuck to the rear final drive and when i pulled it out, the gear came out with it? can i just stick it back in? i noticed when i did if i turn the right wheel to the right the left spins to the left. or when i turn the left to the right the right spins to the left.
That's how it normally works...
If you manually turn one wheel while the car is in the air, the other side turns the opposite way. That's how it's always done on all AWD drive vehicles that I've had.
yup. i eventually hit the inter cv with a mallet and broke the rust seal. but the inner
gear shaft came out with it. it sticks out about..8 inches. i can push it back in but it would probably require a few light hits with the mallet to pop it back into where it was before and create the seal against the output flange on the haldex unit. want a pic?
sjd_boston
06-05-2023 02:49 PM
