tie rod assembly install?
Pop the ball joint off....>
the steering knuckle With a tie rod tool, unscrew old, screw in new. Re-bolt to the steering knuckle, get your Toe aligned.
20 minutes a side if you take a beer break...:-)
or even easier if you just replace the outer end, which is usually the part that wears out... unless
you live in the snow belt, and the adjuster threads are seized due to corrosion.... wouldn't know about that here in Atlanta =)
oh, and tip for popping tie rod end from the steering knuckle....
use a 2-jaw gear puller like this one from Sears...
<img src="http://img.photobucket.com/albums/v323/type89q/tt_cvjoint/P2060002.jpg">
Re: Pop the ball joint off....>
What do you recommend for a ball joint tool? I'm curious as I may need to replace mine soon. I did this job on my old car, but with one of the air hammer attachments meant for ball joints. I'd like something that works mechanically and will not damage any boots in the process.
To remove the lower ball joint (not tie rod end ball joint) for replacement, use a pickle fork....
shouldn't need the air hammer, but use it if you got it. You'll kill the boot, but it gets replaced with the new ball joint.
CarNut68
Audi Original "S" Cars
04-08-2010 12:18 AM
MiB@100-2.3NF-91
07-27-2005 10:43 AM
HEADACHEZ
9
11-02-2004 11:28 AM
