TT Door Panel Component Removal Help
I am in the process of fixing an issue I am having with my door panels (the trim is bubbling up around the window), and I have ran into a little road block. I pulled the panels off the door, but am having trouble trying to figure out how a particular part comes off the panel. In order to fix the problem correctly, I need to be able to access where the trim wraps around the plastic 'backbone' of the door...the problem is that there is a cloth guide thingamagigger the I assume protects water from getting inside the door. Does anyone know how to remove this thing? I'm pretty sure I did a horrible job trying to explain this thing, so maybe the pictures will help... Thanks!<ul><li><a href="http://www.audiforums.com/m_876059/mpage_1/key_/tm.htm#876059">(Pictures can be viewed here)</a></li></ul>
tk1780
Audi 100 / A6 (C4 Platform)
11
04-27-2006 09:01 AM
Meegis
04-02-2006 01:39 PM
Doctor Steve
05-15-2002 01:00 PM
