TTschwing - I found a link that suggests potential for decreased turbo life with.....
...a tighter wound spring in the DV. What do you think?<ul><li><a href="http://www.machvw.com/ilovthatpsso.html">http://www.machvw.com/ilovthatpsso.html</a</li></ul>
Not the case in this case.....
The DV is still opening quite easily at the transition between vacum and boost. 5mm worth of spring shim is not drastically altering the DV characteristics. I've got a boost gauge and have been watching this. If you're worried, don't do it. It's that simple. The problems outlined here are primarily tricks to get a BOV to function in what is supposed to be a closed (DV) type system.
Nobody recommends a BOV for this car.
RGilTT
13
06-29-2002 09:30 AM
