Turbo disconnect
Turbo disconnect
Hi, I have a 2001 TT 225 hp and i would like to just temporally disconnect the turbo from kicking in, so i can get my smog check taken care of. The simplest way would be most welcome.
The ECU map is expecting a certain amount of air and fuel at a given RPM, your car might do fine at low RPMs (no boost) but anything above that is probably going to throw a code.
thats not really the problem. When they try to run the test at 2500 rpm the turbo kicks in and won't let the car run at 2500 for long enough to accomplish the test. They can't put it on the dino because it's a Quattro so they have to run the test on the floor. every time it reaches 2500 the rpm's jump up and the test hast to be run at 2500.
vtraudt
1.8T Discussion
11-05-2017 07:27 AM
Nick Robinson
03-04-2003 01:15 PM
