Turbo Flutter and slight delay-After New Stock Turbo
#101
here——. https://audi.7zap.com/en/usa/
What year is your car again?
#103
Well...I am back. The saga continues.
ECS Tuning had the CAT on back order...for a long time. So I cancelled the order and picked up two walker universal CATs to be welded.
I towed the car to my local muffler shop that does welding. Well....they didn't weld it. They did a compression test on the exhaust and it was good. They took the CAT off and the mechanic said he could see thru it and it was not clogged. He checked the flex pipe with camera..all good. He did find one code for the MAF sensor, but I told him the MAF was new. He found the intake hose to the turbo was off. So he clamped it back on and called me to come get the car that the only problem the car had was the intake hose having come off.
I picked it up after hours when the shop was closed. When I drove it home, it did not boost. No boost..no turbo..just exactly back to where I was before it stopped running.
I have this Ross-Tech tool and I have no clue what to test first.
Can someone guide me how to test the Mass Air Flow sensor?
Thank you
Thank you
#105
I’m not surprised that the cat was not clogged. Have you unplugged the MAF and checked if it runs better? That will give a CEL but it will go away when plugged back in.
http://www.ross-tech.com/vcds/tour/main_screen.php
#106
A while back I unplugged it and it didn't seem to do anything but give me a MAF code. The car ran the same, with no boost . I could try again.
I'll do the autoscan when I leave work tonight in the parking lot. The mechanic cleared the codes...but it's been a good 80miles since then. Something should come up by now.
So it should be easier to determine what is wrong correct , now that I have a full VCDS and cable from Ross-Tech?
#107
Yes. Easier. Not necessarily easy but we were working blind before.
#108
Monday,26,February,2018,18:10:37:41079
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
Ross-Tech: Home
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: None
Part No: 8N0 906 018 S
Component: 1.8L R4/5VT G01 0004
Coding: 06600
Shop #: WSC 01236
VCID: 41DFBB89D893CD7F3D6-513C
3 Faults Found:
16487 - Mass Air Flow Sensor (G70)
P0103 - 35-10 - Signal too High - Intermittent
17743 - Engine Torque Monitor 2
P1335 - 35-10 - Control Limit Exceeded - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-10 - Malfunction in Circuit - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20.lbl
Part No: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 01236
VCID: 3C21CA7DBF71A0976E0-4B00
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
16-00 - Signal Outside Specifications
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00140
Shop #: WSC 01236
VCID: 678B45119677D34FD32-2580
No fault code found.
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F1B1DF10EA7DB8F6B2-4B00
Address 35: Centr. Locks Labels:. 8Nx-962-267.lbl
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
VCID: 3FDBBD71AE67BB8F4B2-4F0C
11 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00957 - Key 3
01618 - Automatic Convertible Top Valve 2 (N272)
29-00 - Short to Ground
01109 - Hydraulic Pump Relay (J321)
01482 - Motors for Central Locking
29-10 - Short to Ground - Intermittent
00951 - Tailgate Central Locking Motor Relay (J398)
01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
01615 - Tank Door Remote Unlocking Switch (E204)
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
VCID: 3D27C779A46BA99F59E-50F4
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 01236
VCID: 65974F196C7BC15FE1E-513C
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8N0 035 186 A
Component: Radio D03
Coding: 00517
Shop #: WSC 01236
VCID: 2E05F035790D4207D04-4B1E
End----------(Elapsed Time: 02:19, VBatt start/end: 13.7V/13.6V)-----------
Ross-Tech: Home
Coding: 06600
Shop #: WSC 01236
3 Faults Found:
Coding: 13504
Shop #: WSC 01236
2 Faults Found:
35-00 - -
Coding: 00140
Shop #: WSC 01236
Coding: 15884
Shop #: WSC 01236
11 Faults Found:
35-00 - -
00955 - Key 1
00957 - Key 3
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
35-00 - -
Coding: 00010
Shop #: WSC 01236
Coding: 00517
Shop #: WSC 01236
#109
Wow, what a horrible time you are having with this car. I feel bad for you
Possibly a weird question, but has anyone checked the clutch? A clutch just starting to go that only slips under full throttle or high rpms would make the car feel like it has a lack of power. Considering your tach doesnt work it might be harder to tell because you cant see the rpms.
I hope you get it figured out soon, I would seek out a local audi/vw guru.
#110
Clutch is new.
I can see RPMs if I need to with a scanner or now with the VCDS.
Something keeps leading back to MAF. So either I was sold a bad MAF or something else within the cable harness...maybe even possible the ECU.
We'll see where this all leads to. J. Patterson maybe able to lead me to the next VCDS test to run. Hopefully it will lead to the issue. If not, if it leads me back to Audi, I will at least be more informed.
Carol
Carol
