Turbo Flutter and slight delay-After New Stock Turbo
#11
Smoke testing is very easy and should yield good results but make sure you do it in an are where you have little wind if possible so you can easily see and trace the smoke.. Does it sound anything like this?
#12
Yes!!! Exactly!
So let me make sure I ordered the correct one, to make sure we are talking the same thing. I purchased 06A 145 710P. That's the diverter valve correct or is it another part#?
Carol
Carol
#13
#14
Yep thats a typical Bosch valve (OR OEM AUDI Branded). They have a very fragile diaphragm in them which is prone to flutter when they go bad. Try an experiment...... Take the valve out and flip it around and see if it still makes the same noise...Possibly installed backwards which can cause light flutter also.
#15
It made the sound with the old valve. That's why I bought the new one. After everything was changed, it didn't make the sound for maybe a week, maybe two weeks, then the flutter came back.
Damn...I just missed my 30day warranty on that part. I'll go to the dealership at lunch time tomorrow and buy a new one. Is it hard to change? I might have to pay someone to change it again.
#16
#17
Awesome! I will attempt this next weekend to do it for sure now! I guess I'll check first to see if it was accidentally placed on backwards. It is possible, because though it does still flutter...it doesn't do it as loud as it did before changing this valve.
Do you think there is also still a vacuum leak since the car does seem to run almost perfect when its really hot outside?
#18
It is possible it may have a vacuum leak still.. I would test just to be sure. How does the car run in the cold mornings or evening?
#19
You can always do something like this and never have an issue with it again except for a clean and grease every 30-40K or so.
https://www.ecstuning.com/b-forge-pa...black/fmdv008/
#20
In the mornings it starts normally fine. But I don't know exactly how to explain it...hmmm...how do I say it....when I take off in the mornings, going to 1st to 2nd...it can seem like its rev'd really high...and I have to change gears, and there is no ummmph behind it. Does that makes sense? But once I've driven it for a good 15 minutes, at time it gets better and I can jam fast and get up to a higher speed at a lower gear..no problem without it feeling so rev'd and forced.
Unfortunately the tach isn't working so I can't really see what's going on rpm wise. I guess I could hook up a scanner and try to look at the monitor for sec to at least try to capture the rpm at that moment.
