Two clips on hood latch cable loose: pinched and replaced; four corner plastic screws on belly pan
tightened; bolts on engine and transmission mounts checked for tightness (they were tight); checked heat shield behind turbo and also thin medal shield over tie rods (I think): sprayed the latter with a little bit of undercoating (if it gets too hot, it will just heat up and burn off); and, moved the SAIP air intake hose to another location.
ONE of these stopped not just the added vibrations from shifting the sub-frame, but now I don't hear the one that's existed since getting the car!
CD player, glove box, and right front area of dash still vibrate, but have a fix for all of them (graphite, inspection, and felt, respectively).
And, BTW, replaced the fuel injector seals in about 15 minutes from start to finish. Is easy when the right parts are sent!
Did you do this do the fuel injector rail? See pic >>
Rid yourself of all the plastic guides . . . cleans up nicely.
<img src="http://images41.fotki.com/v1346/photos/4/41970/6648249/DSCN9840-vi.jpg">
The FPR nipple points towards the battery just a tad. Position it so the hose is comfortable.
<center><img src="http://images42.fotki.com/v1314/photos/4/41970/6648249/DSCN9837-vi.jpg"></center><p>
I found torque on dogbone to be critical in preventing vibrations
When I put my Polyflex bushings in. Probaly the same for the engine and tranny mounts. You need some serious muscle to torque the stretch bolts to spec +90 degrees.
AudiSpaulding
11-16-2007 10:43 AM
UrScubed
Audi Original "S" Cars
12-23-2006 11:48 AM
polishadonis
10
11-15-2005 05:31 AM
Greg PAW
12v V6 Discussion
14
02-06-2004 04:57 AM
