Vag-Com Fault Codes.....
I just purchased a Vag-Com from Ross-Tech and ran an auto scan this morning. As most of you know I just recently got my car back since the accident in Nov. Well after running the auto scan this morning the body shop did not have all the codes cleared after the accident. One of which was a result of the NO BOOST when I picked up my car and it had a broken boost line from the intercooler. I went ahead and cleared these codes since they were a result of the accident. I am going to drive the car for some this weekend and do another auto-scan. Here are the fault codes that were detected.
Address 01: Engine
Part No: 8N0 906 018 AN
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 65728
TRUWT28N521033852 AUZ5Z0B4146046
4 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
17832 - Secondary Air Injection System; Bank 1: Leak Detected
P1424 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Address 35: Centr. Locks
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D06
Coding: 15980
Shop #: WSC 01236
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
Address 01: Engine
Coding: 06710
Shop #: WSC 65728
4 Faults Found:
Coding: 15980
Shop #: WSC 01236
5 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
I have a Bailey's DV, but I think the code was a result of the broken ...
boost hose after the accident. I just drove the car to lunch and the DV seems to be working fine. No odd noises or anything. I am going to run another auto scan tonight to see if any of the faults show up again. If they do not then I know that it was result of the accident and everything is now fixed. The car was started and moved several times right after the accident which probably caused it to show these faults.....thanks
iProDrive
VAG-COM Discussion
04-20-2006 01:15 PM
carlosii
VAG-COM Discussion
05-03-2004 06:33 AM
