VAG-COM - protocol for running??
Should I have the doors shut and windows up, stereo off, in gear, etc. while running the Auto-Scan? So far it has complained about the airbag module, but is still running...
Results for the first log... 3 faults...
Address 22: AWD Labels: 02D-900-554.LBL
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 35: Centr. Locks Labels: None
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D05
Coding: 15884
Shop #: WSC 01236
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
1 Fault Found:
00-00 - -
Coding: 15884
Shop #: WSC 01236
2 Faults Found:
35-00 - -
00956 - Key 2
I had 2 of those faults
adaptation of the key...means it has been pressed 200 times or more.
Alarm trigger internal monitoring also...
I wouldnt worry about it.
Go here for explanations of fault codes and remedies<ul><li><a href="http://wiki.ross-tech.com/index.php/Main_Page">Ross Tech wikipeadia</a></li></ul>
