vagcom block help
ive never used my vag before, and i dont really have the luxury of playing around with it. i was hoping somebody could tell me block numbers for:
-lambda (first o2 sensor) -MAP -MAF -injector duty cycle -oil temp would be much appreciated. |
My $.02 worth...
Injector period is block #002, cell 3
MAF also appears on that block, cell 4 MAP is logged on block #204 lambda (both sensors) is block #31 if I remember correctly (could be #33). It displays the voltage of both sesnors, O2S1 which is on the exhaust manifold and O2S2 which is after the cats. Also useful: #004 is intake temp (cell 4) #214 is exhaust temp (should not go beyond 960*C or the K04 will suffer) #013~016 is misfire #003 or 004 also displays ignition advance. |
