VagCom works finally, and....
Hex+Can USb, works great right out of the envelope unlike my Ebay KKL ripoff cable.
Anyway, here are the only 2 codes in the entire car:
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
2 Faults Found:
01538 - Motors for Headlight Range Adjustment (V48) / (V49) 29-00 - Short to Ground
00776 - Level Control System Sensor; Left Front (G78) 31-00 - Open or Short to Ground
Anyone run across these faults before?
2001 Audi TT 225 Quattro 6 speed
Coding: 00010
Shop #: WSC 01236
2 Faults Found:
Start by clearing it and see if it comes back. Sometimes you will get nuisance codes like this one
every now and again. If it comes right back, then you know you have a true fault. In this case it should be an easy fix. The headlight level switch attached to the drivers front suspension arm is the likely culprit. You can change it with just the wheel/tire off.
CME's01S8
09-02-2014 04:32 PM
2003Quattro1.8T
03-28-2009 07:35 AM
gragravar
Audi allroad
12
09-02-2007 06:02 PM
