what could cause all these codes...alternator? supply terminal 30 voltage low
Old 02-08-2009, 03:39 PM
MaD MaTTer's Avatar
Default what could cause all these codes...alternator? supply terminal 30 voltage low
I had not driven my car in about 2 months due to injury, i drove it on thursday and friday with no problems, then saturday the gauges started going crazy, the headlights turned off while driving, the "yellow" battery symbol turned on in the HUD and finally it went into hard limp mode as i was looking for a parking space.
I bought a new battery and put it on, it started, drove it for about 30 miles and the "red" battery light in the speedo started flashing went into light limp mode for a few seconds before i got to my sisters house. couls it be the alternator or possibly something else here are the codes i pulled the second time. the first time it happened it pulled similar codes.
Address 01: Engine
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0110 1001
Address 15: Airbags Labels: None
Part No: 8N8 909 601
Component: Airbag Front+Seite 2008
Coding: 10103
Shop #: WSC 01236
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 22: AWD Labels: 02D-900-554.LBL
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 35: Centr. Locks
1 Fault Found:
00668 - Supply Voltage Terminal 30
Address 45: Inter. Monitor Labels: None
Part No: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-10 - Supply Voltage Too Low - Intermittent
Address 56: Radio
2 Faults Found:
00855 - Connection to CD changer
49-10 - No Communications - Intermittent
Old 02-08-2009, 07:29 PM
MaD MaTTer's Avatar
Default UPDATE: Just got the car home. put the voltmeter to it and got 11.06V while idling
gotta be the alternator right?
Old 02-08-2009, 08:17 PM
DumpTTruck's Avatar
Yup. Internally regulated so its shot. Replace away! Get your new battery on a charger soon
Old 02-09-2009, 03:57 AM
AudiWorld Uber User
TTschwing's Avatar
Default Yup......>
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1730191.phtml">Battery 101....</a></li></ul>
Old 02-09-2009, 04:55 AM
MaD MaTTer's Avatar
thanks, going to try and locate one locally to swap it out after work.
S4MAFIA
08-11-2012 06:26 PM
S4MAFIA
2.7T V6 Discussion
08-09-2012 02:24 PM
The Red October
07-12-2010 05:33 AM
red90q
9
08-27-2007 07:23 AM
Jack in FL
Audi 100 / A6 (C4 Platform)
12
07-26-2003 02:02 PM
Quick Reply: what could cause all these codes...alternator? supply terminal 30 voltage low
