What do you need for a oil pan change? A gasket? Also, any aftermarket headlight bulbs you guys....
recommend?
There is no OEM gasket, but you may wish to use some blue gasket goo on it...
You are gonna need some decent wrenches for the pan, 10mm socket, 5mm ball end, some nice big bolts on the tranny side, like an odd size if my memory serves 18 or 19mm
<img src="http://www.wttool.com/images/normal/67030040.jpg"> |
New Oil Plan?
<ul><li><a href="http://forums.vwvortex.com/zerothread?id=4197764&page=1">http://forums.vwvortex.com/zerothread?id=4197764&page=1</a</li></ul>
I got a pair of 5000k bulbs from these guys.. they seem to be alright especially for the price
Make sure you read the description and get new bulbs, cause they also sell used ones..
Fast shipping and they even threw in some alcohol pads to clean the bulbs before you put them in :] Check it out<ul><li><a href="http://stores.ebay.com/Retrofit-Source-HID-Retro-Parts_HID-Bulbs_W0QQcolZ4QQdirZ1QQfsubZ3177472QQftidZ2QQtZkm ">Headlight link</a></li></ul> |
actually the OEM "gasket" is a tube of black goo... i'd recommend using the OEM stuff
would 6000k work or is there a problem with doing that?
I'm sure they will work as long as they are D2S and 35w..
-Colby l
