What is this thing? (+ foglight question)
I am trying to give my Mk1 an updated look with some LED strips. I thought to myself that it would be easy to just wire them into the fog light wiring. I have the switch that controls fog lights, however I don't have any fog lights.
Looking behind the front bumper I saw this thing. I thought it might be a OEM connector for Audi fog lights so I cut it and checked the voltage. .2 when the car is off and 5 volts when the car is on. Too little to run the LED strips so I ran the part number that was printed on it and nothing came up.
I thought it could be the temp sensor for outside air but that still works fine with this thing removed. Any idea what it is?
Any idea where I can run a few wires through the firewall to the fuse panel?
It's low voltage which makes me think it's a sensor. The way it's clipped just over the washer fluid line for the headlights makes me think it's not too important.
Drives fine.
Drives fine.
Funny because it still reads correct. Based on it's location I didn't think it was too important. I cut it off to check the voltage thinking it might be some strange connector for stock fog lamps but the voltage was too low indication it was a sensor of some sort.
Wasn't as if the TT was going to die without it.
Any ideas for the new lights? I can't seem to find an area to connect to a 12 volt that works with the headlights in the engine bay.
BTW python, I'm trying to do what you've done but not go too far into it. There is a gap between the headlight and bumper I can fit the thin LED strip into but I think I'm going to try to mount it where the fog lights would go.
AudiWorld Awesome User
Good luck on the future performance off the engine.
I'm constructing a "found art" piece and have been collecting small parts that have been randomly clipped from otherwise perfectly operating automobiles. I'd like to include this in my artwork. Please send this to me and I will include this part in the installation.
Other parts I am looking for are:
1/2 Coilpack
Most of a TIP
Some random radiator hose
Water pump impeller
Timing belt with 12 stripped teeth
Thanks.
j/k
1/2 Coilpack
Most of a TIP
Water pump impeller
Thanks.
j/k
Your Audi card is hereby revoked. Outside air temp plays a rther important role in density correcting your air-fuel ratio. Never importatn for a turbo (sheesh). Especially if you live in a temperate place where temperatures vary by more thana few degrees.
