What's the size of our rear license plate light bulbs? Mine burnt out.
<center><img src="http://images7.fotki.com/v133/photos/4/435091/1612506/04RemoveLight1-vi.jpg"></center><p>
..might have been a voltage spike.
Which one of these <a href="http://store.42draftdesigns.com/Fuse-Style-LEDs_c_39-1.html">LED replacements</a> would work? The 39mm or the 42mm? I know they are the fuse style bulbs.
I used this <a href="https://forums.audiworld.com/tt/threads/455952.phtml#1805588">post</a> as a reference...<ul><li><a href="https://forums.audiworld.com/tt/msgs/1730247.phtml">FAQ help</a></li></ul>
Use the 39mm fuse style, as I read the site, the 42mm are not specified
for license plate use.<ul><li><a href="http://store.42draftdesigns.com/145v-White-39mm-Fuse-Style-LED_p_39-32.html">14.5v White 39mm Fuse Style LED</a></li></ul>
I actually measured the OEM bulb and it was exactly 39mm..>>>
Currently have 42DD LEDs and they have been working great for about a year now with no problems. Nice, white, and brite. It even lights up the ground at night.
If you are looking for a local replacement: Sylvania # DE3423 ..>
The Sylvania # DE3423 can be found in many local auto parts stores. I measured the one I have in my housing and it's 36mm.
If you find the cheap crappy plastic clip on the housing is cracked then take a look at the URL link. If it isn't cracked yet, it will be soon. I used RTV silicone to strengthen the clip and that seems to work well as an alternative to buying a replacement from the stealership.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1805581.phtml">https://forums.audiworld.com/tt/msgs/1805581.phtml</a</li></ul>
Thanks! Would these high intensity ones fit?
<ul><li><a href="http://store.42draftdesigns.com/High-Intensity-39mm-Fuse-Style-LED_p_39-37.html">Here u go..</a></li></ul>
theonlineguy
10-10-2007 08:23 PM
djillusion
03-22-2007 06:18 AM
