wheel bolt question>>
if i have wheel bolts right now that are 27mm long and I add a 8mm spacer the 35mm bolt is the right one correct?
Yep. If aftermarket wheel, make sure to get the conical seat bolt.
thanks MarTT one last stupid question is this the correct one>>
DR Series Wheel Spacer - 8mm (1 pair) - Version 2 ES#246
For OEM wheels with larger wheel bore chamfer. Also some aftermarket wheels like BBS. for oem wheels? Right from ECStuning's website |
Yes that looks right, since you are staying with OEM wheels, the longer bolts
need to be "ball" or "rounded" seat. ECS has a good page explaining all this at the link below.<ul><li><a href="http://www.ecstuning.com/HR/support/how_to_mesure.html">http://www.ecstuning.com/HR/support/how_to_mesure.html</a</li></ul>
Better to check to be sure... My new wheels use ball seat bolts
