why is my TT overheating when the coolant level is correct?
#11
#13
FYI, The fans were not running because the radiator was not hot. Hot coolant was not circulating therefore the fan thermostat switch was not being actuated. Another diagnosis clue I should have mentioned.
#14
It's only a few things
If its your thermostat your bottom coolant hose will not get hot while your top coolant hose does, if that's it, pull your thermostat, drop it into boiling water and see if it compresses. If it does, then your thermostat is fine.
Which means the next thing:
Open your coolant ball, pull your return hose, hold over the coolant ball opening and see if you have strong flow. Which means you have good circulation of coolant which means that your water pump is working well.
If you have slow or dribbling flow, congratulations, you have just become another victim of Audi's infamous plastic waterpump impeller and it needs to be replaced.
#15
#16
Hi it was both of those things! The thermostat and the water pump- they changed the timing belt for good measure which was all cracked. So now Finn gets crossed all good for another 60,000 miles! Thanks guys x
#17
mxmissile
08-08-2018 06:48 AM
MelloYelloS4:Indkted
16
01-19-2005 09:32 AM
