Window switch adj?
On the door locking striker there is a small plastic switch that controls the window creep- when you open or close the door. Is there an adjustment to the switch ? The switch works, but seems out of adjustment.
Thanks
https://www.audiworld.com/forums/sho....php?t=1929857
Now if your window is simply not going all the way up or down, that is not a micro switch but simply a window reset issue.
". If your windows do not drop and raise
when you open and shut the doors,or if the one touch does not work ,it's
because the battery has been disconnected and the window drop memory feature has not reset.First raise the
window all the way up then release the switch then hold it up for 1-2
seconds ,this will reset it."
Seems like it needs adj. Is that possible ? Or does the whole lock need to be replaced?
Thanks for all....
