Xenon Time!
Xenon Time!
I was doing some research into how to adjust my xenon's on my '01 225QC. Some people in audiworld talked about using the screw type white plastic ***** under the hood, while others mentioned using a VAG-COM. Do they both accomplish the same thing? I tried adjusting the white ***** with a philips head, but it didn't seem to do anything. TIA.
Also, has anyone done a xenon/hid/led mod to the fog lights. I really don't see these lights as being that useful in the fog, they seem pretty weak. TIA again
Careful with those *****>>
according to a buddy who is a dealer tech, you need to first access the Xenon control module and put it in a correct mode (adaptation selection I believe), otherwise the adjuster motor can be damaged.
and you need a t-handle allen, think it's either 5mm or 6mm, to adjust.
I did mine as they were too high after some suspension work (didn't get the sensor arm back in the correct spot on rear control arm) and it worked fine.
Big D
02-01-2002 04:48 PM
coolGuy
02-15-2001 06:39 PM
