09 Audi tt sputtering?
78,586 miles im going down the interstate arou d 75 mph and the car starts sputtering, so i turn the engine off and it wwont crank..... no check engine lights at all... not sure whagt the problem(s) are any ideas? 2.0 tFSI BPY
Not enough details. If you mean the motor won't turn over, my first guess is a bad alternator resulting in a dead battery. If it turns over but does not start, it could be the timing belt (the 2.0 base TT went from belt to a chain during the 09 MY). Hopefully, it is not this because it means that your car is totaled. The most common cause of quick onset sputtering is coil packs but usually coil pack failures generate CELs.
BTW, if I had an 08 or 09 with a timing belt, I'd get it and its associated parts replaced pronto. 10+ years on a piece of heavily used rubber is a long time. Why risk a $5K+ repair from a failure? How do you know if you have a belt? Read this FAQ https://forums.fourtitude.com/showth...-MK2-TT-a5-FAQ
Lakesdri
SoCal Discussion
07-06-2018 09:28 PM
Earnest Aviless
Performance and Tuning
02-17-2013 02:09 PM
dan4g63
12v V6 Discussion
07-01-2008 01:55 PM
