TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
2008 Audi TT spare tire
Old 06-11-2011, 06:17 AM
  #31
Namderd's Avatar
Default Jack
In Car Scissor Jack
ES#:302185
Mfg#: 1H0011031
From ECS Tuning. It is currently listed for $9.38, backordered.
Go to the ECS site, select Audi, TT, MkII, Quattro, 3.2. Then search for jack. Several options.
Old 08-22-2012, 09:07 PM
  #32
reedog117's Avatar
Default Would Volvo S60R/V70R spare tires work on a TTS?
Has anyone tried any of the Volvo 115x85 R18 rims as a spare tire? I see a ton of them on eBay with fitments for S60R's and V70R's from 2004-2007 so I was wondering if these might work.
Old 02-28-2013, 03:13 PM
  #33
AudiLvr3's Avatar
I went to discount tires website and put in my tire size on my 2008 TT 17" wheels (225-50-17R) and there were many choices for tires under <100, and 1 rim <100, for a total price of 200.
Can't I use any tire/rim combo with my size as a spare (and preferably, cheapest since I'll only need in emergency situation), or am I missing something?
Old 03-01-2013, 06:11 AM
  #34
Vegas-roadster's Avatar
Default You're not missing anything look a few pages back for a better thread on this topic
The 2 best proven options are:
1. Use the compact spare from a 2008+ A4. About $400 new but can be found much cheaper in junk yards, one poster found it for $100.
2. Nearly full size spare, buy a cheap 16x7 wheel and the cheapest 205/60/R16 tire for about $200 installed. This gives a tire diameter almost identical to the stock 18" tires and works fro all other TT/TTS/TTRS tire options.
For the RS these spares only work on the rear, so if you get a front flat you must move the rear tire to the front and mount the spare on the rear.
I went with option 2 because I can store things within the rim and you do not have any distance or speed restrictions. Disadvantage is it's a little heavier and a few inches wider.
Folks interested in the UK posting of cutting out the exsiting foam to hide a compact spare do not realize that there is much more involved than just cutting foam.
Old 03-01-2013, 06:13 AM
  #35
Default There is a newer/better thread for this a few pages back - summary
2. Nearly full size spare, buy a cheap 16x7 wheel and the cheapest 205/60/R16 tire for about $200 installed. This gives a tire diameter almost identical to the stock 18" tires and works for all other TT/TTS/TTRS tire options.
Old 03-01-2013, 09:49 AM
  #36
AudiLvr3's Avatar
Thanks Vegas, quick question:
Would it be better to get the stock size you mentioned (205/60/R16) or my current size which is 245/40Z/R18/97W ?
Also, I thought the stock tire size was 17"?
Old 03-01-2013, 04:46 PM
  #37
Default Depends on what you want
Don't know your definition of "stock" is. Mk 2 TTs were sold with 17", 18" and 19" rims. Maybe OEM is a better term.
This and the other thread discused "compact" spares. Of course you can buy a full size spare that matches the rim/tire you are runing. It is just wider and hevier than a compact spare. Since I own a roadsTTer, trunk space is scarce and I doubt a full size spare would even fit in my trunk. The almost full size concept objective was to find the smallest cheap rim that clears the TT brakes and choose a tire for that rim that provides the correct diameter. It's about 2" narrower than an 18" tire/rim and 3" wider than the A4 spare. For me, the "almost full size" is better because I can use the inside of the rim as storage space. The A4 spare must be stored "open side down" or it will slide around the trunk due to the design of the rim. Of course. if you plan on modifying the foam area below the floor, the A4 is the only choice.
Old 04-26-2017, 05:28 PM
  #38
jetrider's Avatar
Originally Posted by Namderd
I ordered a jack from ECS Tuning. $9.95 it has arrived and looks to be OEM.
Just a note for anyone with 18" wheels. The spare does not fit my 2008 3.2. I am in the process of moving the "hump". Not for the faint of heart.
Hi Namderd , I'm where you were a while back, also unhappy with the spare fit in the trunk. Did you move the hump? I read the vapor canister is in there. Like to cut an inch or so out but............ thanks
Old 04-26-2017, 08:37 PM
  #39
Default Removing the hump is a bad idea
It effects structural integrity. The euro versions do not have the hump and that is why it is possible for them to re-arrange things under the trunk cover.
RWBaconTT
TT (Mk2) Discussion
02-28-2018 08:20 AM
scottkch
TT (Mk2) Discussion
08-23-2017 07:21 AM
- GT Style -
Vintage Audi Discussion
07-18-2007 03:58 PM
Dylan'74
05-10-2003 06:34 AM
Quick Reply: 2008 Audi TT spare tire
