2013 Audi TTS Prestige Build
#22
#23
Great running into you here!
Don't want to HiJack this thread... if you have any homework RE the RearSway bar and some of the questions above can you please post them as a reply to my threat I started last night here under the TT Mk2 Discussion area please?
#24
I'm glad to jump in and share my experience. Yes I'm concerned with CARB, I have a good relationship with my tuner so when smog time comes I will take it in and have stage 1 loaded, then smog. I have a 42 Draft Designs downpipe with cat, resonator, and stock after that. I had it checked after install and it passed with stage 1.
#26
My car has 33000 miles currently. I want to encourage you to check the HPFP cam follower often, my car had 32200 when mine failed. The total cost to repair was $2700 but I had a worked HPFP installed for stage 2+ which was $800. New cam, cam follower, gaskets/seals, and 10 hours labor.
#27
#28
#29
That's true but with the stock cat back it sounds stock too. My county is pretty relaxed unlike other counties in this state. They would also have to jack the car to see the DP also. If I fail, it's not hard to swap DP's. Believe me I struggled with the decision to go stage 2 but the power is so addicting.
#30
