Good candidate for a replacement factory head unit?
Hoping to replace the factory installed bose concert head unit (non lcd screen) with something a bit more modern. Would this be a good candidate replacement head?
That should work. You'll need new harnesses and adapters I'm sure. Try looking at these links for more information,
Connects2 Ltd
or here
enfigcarstereo.com
I often wished I'd replaced ours rather than adding the Dension to the existing head unit.
Enjoy shopping!
Connects2 Ltd
or here
enfigcarstereo.com
Enjoy shopping!
Yeah that will definitely work, i got the appradio don't use cds so this worked for me and it gives it a great look. Steering wheel controls work as well but you do need the harness and adapters.
Thanks for the suggestions so far. I have picked up a 2330NEX and all of the relevant harnesses from enfit. I also did read the battery drain post and am now curious about this car possibly having an aftermarket in the past. I noticed a small, nicely installed switch directly under the factory faceplate. Really has me wondering if it wasn't a possible kill switch for a deck.
At any rate I am going to investigate the switch and the rest of the setup once the harness arrives.
Cheers
Cheers
HACK THS
09-06-2001 10:59 PM
js
08-20-2001 01:36 PM
js
08-19-2001 06:04 PM
Jeff
11-05-1999 05:35 AM
