TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
Headlight issues
Old Nov 23, 2018 | 09:37 AM
jpelkone's Avatar
Default Headlight issues
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-unhide:no;
mso-style-qformat:yes;
mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:Cambria;
mso-ascii-font-family:Cambria;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:"MS 明朝";
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Cambria;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;
mso-ansi-language:EN-US;}
a:link, span.MsoHyperlink
{mso-style-priority:99;
color:blue;
mso-themecolor:hyperlink;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{mso-style-noshow:yes;
colorurple;
mso-themecolor:followedhyperlink;
p.MsoListParagraph, li.MsoListParagraph, div.MsoListParagraph
{mso-style-priority:34;
margin-top:0cm;
margin-right:0cm;
margin-bottom:0cm;
margin-left:36.0pt;
mso-add-space:auto;
font-size:12.0pt;
p.MsoListParagraphCxSpFirst, li.MsoListParagraphCxSpFirst, div.MsoListParagraphCxSpFirst
mso-style-type:export-only;
margin-top:0cm;
margin-right:0cm;
margin-bottom:0cm;
margin-left:36.0pt;
mso-add-space:auto;
font-size:12.0pt;
p.MsoListParagraphCxSpMiddle, li.MsoListParagraphCxSpMiddle, div.MsoListParagraphCxSpMiddle
margin-top:0cm;
margin-right:0cm;
margin-bottom:0cm;
margin-left:36.0pt;
mso-add-space:auto;
font-size:12.0pt;
p.MsoListParagraphCxSpLast, li.MsoListParagraphCxSpLast, div.MsoListParagraphCxSpLast
margin-top:0cm;
margin-right:0cm;
margin-bottom:0cm;
margin-left:36.0pt;
mso-add-space:auto;
font-size:12.0pt;
.MsoChpDefault
{mso-style-type:export-only;
mso-default-props:yes;
@page WordSection1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:36.0pt;
mso-footer-margin:36.0pt;
mso-paper-source:0;}
div.WordSection1
{page:WordSection1;}
/* List Definitions */
@list l0
{mso-list-id:340009756;
mso-list-type:hybrid;
mso-list-template-ids:1163818258 67698689 67698691 67698693 67698689 67698691 67698693 67698689 67698691 67698693;}
@list l0:level1
{mso-level-number-format:bullet;
mso-level-text:;
mso-level-tab-stop:none;
mso-level-number-position:left;
text-indent:-18.0pt;
font-family:Symbol;}
@list l0:level2
mso-level-text;
font-family:"Courier New";
mso-bidi-font-family:"Times New Roman";}
@list l0:level3
mso-level-text:;
font-family:Wingdings;}
@list l0:level4
mso-level-text:;
@list l0:level5
mso-level-text;
@list l0:level6
mso-level-text:;
@list l0:level7
mso-level-text:;
@list l0:level8
mso-level-text;
@list l0:level9
mso-level-text:;
-->Apologies if there already is a discussion thread on upgrading earth on Audi TT MK2, I simply can’t find one.
Need some guidance with my Audi TT 2007.
Just fixed the rear brake light issue with new ground wiring and they now work like magic, thank you for the advice on that scottmechanics
The challenge is that I’ve also lost the Xenon front lights.
· First the left front on low beam.
· Then Right front on low beam.
· And soon after both high beam.
Park lights are ok.
Indicators work.
Does anyone have a wiring diagram for the 14pin front light connector please?
When I measure the readings I am getting the following on both.
1) 2.5
2) 2.5
3) 0
4) 12
5) 0
6) 12
7) 0
8) 0
9) 0.4
10) 0.4
11) 0.6
12)0.4
13)0
14)0
When measuring the ground (resistance) from the battery to connector I am getting.
Left 0.34
Right 0.19 to 0.56 changing between measurements
So to me it seems like the earth connection might be a problem.
Does anyone here know where the earth connection points on 2007 Audi TT are?
Would be good to clean these up or upgrade the wiring.
Just for the record the battery reads 13V standing – almost 14V when the car is running so it all seems ok.
OBD-codes that I have are
02769
02233
and tons of others for poor/disrupted connection.
QuattroHawk
Aug 10, 2008 07:16 AM
Kidquattro
May 14, 2005 01:05 PM
Ben's e//S2
Nov 27, 2003 09:23 AM
