how can I make my 2012 audi play my music from my Samsung S7 (using spotify)?
I have a Audi A4 2012 with a MMI and sat nav.
Does anyone know how can I play the music from my samsung S7 in the MMI? I tried with the cable but it says that it does not support the device. Many thanks.
I am using the Bovee Bluetooth and works for on my 2012 tts with an S8. Is kind of expensive like $87 but that the only good on I could find. I am sure they probably others out there that might be cheaper. The only issue is that it does not display the play list or title of the song. I have not tried spotify yet though. Will update after I do.
Thanks
Great!
If you are connected and playing your music, how does it work if you receive a phone call? can you still answer using the steering wheel keys?
I have not gotten a call in the car yet so can' commet on that. I assume when you get a phone call, you can switch between the call and music.
You can place a call via the AMI/MMI system over bluetooth. And stream music over the other Bluetooth unit. I do it in my 2014 TT. I use the carpro unit from CoolStream since it saves you about $10.
https://www.youtube.com/watch?v=KsBfWgrMapQ
