Go Back  AudiWorld Forums > Audi Models > Audi TT / TT-S / TT-RS > TT (Mk2) Discussion
Reload this Page >
iPhone ashtray CarPlay dock for Audi TT mk2
TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
Old 02-13-2019, 05:20 AM
flux_capacitor's Avatar
Default iPhone ashtray CarPlay dock for Audi TT mk2
Four years ago, I installed an Alpine head unit compatible with CarPlay in my 2010 Audi TT mk2, in place of the old RNS-E sat nav. I have been very happy with it ever since. But I found that connecting and disconnecting the iPhone to the cable in the glovebox was pretty annoying and not well integrated.
I have come up with a solution: I designed a custom iPhone dock to fit inside the TT ashtray compartment. I successfully 3D-printed and installed a first version for my iPhone 6, and now I made another one for my iPhone X:
The dock is now produced by Shapeways, which uses leading-edge professional SLS 3D printers to manufacture goods and ships them worldwide (the result looks like way more OEM than a model made with a home 3D printer).
I wanted to share this design with other people out there so I made this website:
You can see the video showing the dock in action at
As well as the howto video showing the Lightning adapter that makes the dock easily removable if you want to put the original ashtray back (bu you won't want that after having tasted the CarPlay docků):
Any TT Mk2 lover in the world can now install this CarPlay dock! I would be glad to answer any question you may have about it.
Cheers,
FC
flux_capacitor is offline
Old 04-14-2019, 05:03 PM
I was looking to order one, but wanted to make sure if I were to get the Iphone X with case version, it would hold an Iphone 8 as well.
At $90 I would hate to upgrade the phone and not be able to fit it in the dock.
Thanks,
Michael
Mikiejag is offline
Old 04-17-2019, 01:05 AM
Hi Mikiejag,
Yes, this is totally possible. iPhone 8 is smaller (both width and thickness) than an iPhone X, so it slides well into the dock made for iPhone X/XS. It will wobble a bit more than inside its dedicated dock once put in there though, but it works. If you go with the dock for thicker iPhone X + thin case, you'll be able to dock an iPhone X or XS with or without thin case; as well as an iPhone 8 with or without thin case. Who can do more can do less
A combination that might not work however would be to try to insert an iPhone XR into a dock made for iPhone X, as the XR is very wide and is the thickest iPhone ever made.
Old 04-17-2019, 01:29 AM
Short notice about the Lightning T-adapter sold on AliExpress:
Two customers so far complained by email that CarPlay doesn't work with the adapter they bought. Actually it works for most of users, but your mileage may vary. I think a small number of these adapters can be faulty. Chinese sellers out there are well known for their super prices but not exactly for their quality control…
This adapter is advertised to work for CHARGING as well as SYNCING.
The important par here is "sync". Here is a basic troubleshooting to test if it works properly right out of the box.
So, first thing to do when receiving your Lightning T-adapter, is to verify that it indeed syncs your iPhone with iTunes on you computer.
To do so, connect the iPhone to the adapter, and the adapter to your computer using a Lightning to USB cable (an MFi-certified one, preferably an original cable from Apple). Verify the cable is not torn or warped at both end. Verify also there is no ball of dust inside the iPhone Lightning connector. Be aware that some 3rd-party cables (or damaged ones) can charge, but not sync. Hence, you have to try with AND without the Lightning T-adapter to be sure. The goal is to check that your iPhone shows up in iTunes. Try this with you iPhone unlocked before connecting. It it's there, it should work with your CarPlay head unit too. But if your iPhone doesn't appear in iTunes, it won't work with CarPlay neither; in this case it means the T-adapter is faulty and you need to ask the seller for an exchange.
The vast majority of these adapters do work properly, but please run the basic test above upon receipt to confirm.
Old 04-17-2019, 03:19 AM
143.6x70.9x7.7 mm vs 150.9x75.7x8.3 mm
Is it physically possible to have 151mm width?
I have loved this since the first promo video I saw. Been advertising it all over the place, small market though. I would bet many people are in the same predicament I am. Want the elegance of this, but worried next phone wont fit.
Mikiejag is offline
Old 04-17-2019, 03:49 AM
143.6 mm is the height of the iPhone X, not its width… height is not related to the compatibility of a particular iPhone model with any dock, as the iPhone always sticks out of the dock once inserted.
There is no Audi TT dock for iPhone XR and never will (same thing for Plus/Max versions). The XR is simply too large to fit in the TT ashtray and inside the tight path underneath.
I make products that can handle each iPhone model tightly enough, i.e. without too much wobble back and forth when breaking, left to right when turning, or unexceptionally popping out when driving over speed bumps or potholes. Overall, the product is intended to match the look, fit and finish of the Audi TT.
If such wobbling effect doesn't disturb you and you want maximum future-proof that does not match specifically your own iPhone, all I can advise is to go with the largest dock available, that is to say the iPhone X/XS + thin case version.
Old 04-17-2019, 04:11 AM
I am off to purchase the XS with case. Thanks so much for these replies. Helped a lot.
Mikiejag is offline
ltooz_a6_a8_q7
16
09-24-2018 10:38 AM
Bicudo
TT (Mk2) Discussion
06-21-2017 02:14 PM
Randy M
RS4 (B7 Platform) Discussion
02-06-2008 10:10 AM
silver rain
Off-topic Discussion
12-11-2007 12:47 PM
Quick Reply: iPhone ashtray CarPlay dock for Audi TT mk2
