New 2011 MK2 Owner
New 2011 MK2 Owner
Hello! I just picked up a used 2011 MK2 TT Quattro with 69,000 miles. I'm a first time owner and have a few questions:
Thank you very much in advance for your help!
- Excited New TT Owner
- When driving in S mode, I noticed that it stays in 2nd gear until it almost redlines. Sometimes it feels like it's not going to change to 3rd. When I go easier on the accelerator, it does shift to 3rd, but I have to be very gentle on the pedal. The gear changes feel normal when in regular D mode. Has anyone experienced this?
- I notice some rattling in the car when the music is on. I have the regular sound system. Any advice on minimizing these rattles?
- Would you recommend I get an extended warranty on the vehicle?
- I plan to take it in for the 75K mile service when that time comes. Is there anything else you guys recommend I do to keep this car in good shape?
The S mode purposely keeps the car in a lower gear to maximize performance. Hard to judge with the few specifics you provide (rpm, speed, throttle) but it sounds normal.
Sounds like you have a blown/loose speaker. Very few problems with the stereo have been reported.
The Mk 2 is very reliable. The most common problems are 1. failure of the rear tail light connectors (check to insure that the brightness of taillights on both sides is the same) and replacement requires replacement of the entire assembly, 2. failure of mag ride shocks (if the car has that option) after about 7-8 years which cost about $1800 per shock to replace. Most folks are replacing then with standard shocks. 3. Failure of the timing chain system if the motor oil has not been changed per spec with spec oil because the chain oiling port gets clogged with sludge (this is not nearly as common as the shock and light issue). Most extended warranties do not cover shocks and many to not cover lights. I would not get an extended warranty unless you see you already have problem #1 or have mag ride shocks AND you are certain the warranty would cover them.
Check with your dealer service advisor and ask if any service has been neglected for your VIN. (You should have done this before you bought the car.)
I wonder if LED replacement bulbs can mask the problem?
Something to try first
Yes, LED bulbs will mask the problem because the LEDs require less power and the lower the power, the less heat generated to melt the connector.
According to my Service Manager, all Mk 2s will eventually have this problem. Had one of mine replaced recently at the end of my CPO warranty.
Thanks @Vegas-roadster for the info. My car doesn't have mag ride and thankfully, my rear tail lights are both equally bright. I turned the bass setting down to about 45% and that seemed to do the trick with the rattling. As far as I can tell, they don't seem blown out. The sound system overall though is kind of meh...
Here is my baby:
Here is my baby:
Do you have the Bose or Concert sound system? My Concert has no rattles with bass turned up full. Irrespective of the system, there should be no rattles so something is loose.
Pdvsa
14
07-20-2015 09:20 AM
Grouse:3.Slow
Pacific Northwest Discussion
07-12-2006 12:09 PM
