Pioneer AVIC-8000NEX installed... 2014 TT
Just installed this baby, Pioneer AVIC-8000NEX, into my 2014 Audi TT. It is factory equipped with RNS-E (aka Audi MMI Navigation) and Bose sound system. Everything works great; steering wheel buttons, Bluetooth, Bose... Sound quality is so much batter with the AVIC-8000NEX. The sound is improved drastically when comparing with the RNS-E, even with the existing Bose speakers, sub and amp.
Detailed installation write up coming soon... https://cimg9.ibsrv.net/gimg/www.aud...0b6a2b3f17.jpg https://cimg6.ibsrv.net/gimg/www.aud...3606ea5a7e.jpg |
Installation Guide
2014 Audi TT, TTS, TTRS RNS-E Conversion – Pioneer AVIC-8000NEX (AVIC-7000NEX, AVIC-6000NEX, AVIC-5000NEX, AVIC-X8610BS).
** DISCLAIMER: FOLLOW THIS GUIDE AT YOUR OWN RISK. I WILL NOT BE HELD RESPONSIBLE FOR ANY DAMAGE TO YOUR CAR. ** Head Unit: • Pioneer AVIC-8000NEX ($969) https://cimg6.ibsrv.net/gimg/www.aud...ada96d8a30.png https://cimg9.ibsrv.net/gimg/www.aud...d2bde8073e.png List of items I've used for this installation: (All items can be found on eBay) • PAC C2R-AUDI Radio Replacement Interface (Bose friendly, unlike Connects2 adapters) • PAC SWI-RC Steering Wheel Control Interface (Keep all the steering wheel buttons work) • Audi Radio Stereo Removal Tool Keys (To remove the RNS-E) • CONNECTS2 CT23AU05A Dash Kit (It is very self explanatory) • Metra 40-EU56 (40eu56) European Dual Fakra Antenna Adapter (For using the existing radio antenna) • Fakra C male to AVIC green female pigtail RG174 (For using the existing GPS antenna) Around $230 total for parts PAC SWI-RC Steering Wheel Control Interface and AC C2R-AUDI Radio Replacement Interface https://cimg5.ibsrv.net/gimg/www.aud...35739e9c0e.png Metra 40-EU56 (40eu56) European Dual Fakra Antenna Adapter. *Blue wire is connect to a constant 12V https://cimg8.ibsrv.net/gimg/www.aud...e6a1b685c9.png PAC C2R-AUDI comes with two type of connectors. Use only this one for RNS-E https://cimg1.ibsrv.net/gimg/www.aud...0efaa4787d.png A lot of installation manuals for the SWI-RC…. But… https://cimg4.ibsrv.net/gimg/www.aud...53261f9a4e.png You only need this… Read it! It is important… It teaches you how to program the steering wheel controls https://cimg8.ibsrv.net/gimg/www.aud...f9feb64c84.png Optional... *It cannot use the existing GPS antenna, need to wire the included antenna to your desired location. https://cimg1.ibsrv.net/gimg/www.aud...be13ac83e9.png CONNECTS2 CT23AU05A Dash Kit https://cimg3.ibsrv.net/gimg/www.aud...1523419426.png Audi Radio Stereo Removal Tool Keys https://cimg4.ibsrv.net/gimg/www.aud...414dfafce8.png Solderer, solder and heat shrink tubing are optional. Use whatever you want to make sure all the wires are secured https://cimg7.ibsrv.net/gimg/www.aud...3688b7b323.png https://cimg0.ibsrv.net/gimg/www.aud...fba25754b7.png https://cimg1.ibsrv.net/gimg/www.aud...3149765326.png Connection - Wiring https://cimg0.ibsrv.net/gimg/www.aud...642a5cd98c.png Speaker wiring Wire as shown... Same color on the AVIC Power Cord to PAC C2R-AUDI. White to white, gray to gray etc… Even if you have Bose. https://cimg3.ibsrv.net/gimg/www.aud...0dde7656f0.png Connect the RCA cables to the head unit… All RCA plugs are labeled… Remember, Red is right, White is left... https://cimg7.ibsrv.net/gimg/www.aud...fa9f99f3d3.png https://cimg9.ibsrv.net/gimg/www.aud...13d2e4150d.png Removing the RNS-E Use the removal keys to remove the RNS-E… Make sure the key is all the way in. Like this. https://cimg3.ibsrv.net/gimg/www.aud...3c5ce9fe34.png One is behind the screen https://cimg4.ibsrv.net/gimg/www.aud...d2cb3098ac.png When all 4 keys are in, simply pull it out from the bottom. https://cimg8.ibsrv.net/gimg/www.aud...8e60d3d3f6.png https://cimg9.ibsrv.net/gimg/www.aud...222ef3ad3f.png Remove the AMI unit at the glove box by using 2 of the removal keys. Keys holes are located at the bottom of the AMI. After the AMI unit is removed, then remove the AMI module from the AMI housing. You can feed the USB AUX and HDMI cables from the AVIC through the AMI housing and gives a factory look like this. https://cimg7.ibsrv.net/gimg/www.aud...03264d4c74.png I placed the mic here, in the overhead light/home-link unit. https://cimg9.ibsrv.net/gimg/www.aud...124e8fec6a.png There is a hole there that can fit the AVIC mic in….Right next to the factory mic… https://cimg1.ibsrv.net/gimg/www.aud...5fc6b5437a.png https://cimg2.ibsrv.net/gimg/www.aud...a904b37afe.png Feed the mic wire through the visor light as a midway point and then feed the wire down to the A-Pillar and then into the left fuse box trim (FYI there is no fuse box in there…) *For your convenience, remove A-Pillar trim and right fuse box trim. https://cimg4.ibsrv.net/gimg/www.aud...2a3aeb4676.png https://cimg5.ibsrv.net/gimg/www.aud...f2d8e01de4.png Put everything back together after the mic wire is fed through https://cimg6.ibsrv.net/gimg/www.aud...499d3b25d1.png Don’t have to remove any screws and the bracket https://cimg8.ibsrv.net/gimg/www.aud...29d1134dd1.png Put the black CONNECTS2 trim on first, then the CONNECTS2 bracket. Don’t forget to transfer the passenger air bag warning light (circled in red) to the CONNECTS2 trim from the RNS-E. https://cimg9.ibsrv.net/gimg/www.aud...18261ab78e.png https://cimg0.ibsrv.net/gimg/www.aud...b5dfd8e82c.png Connect everything and wala! https://cimg1.ibsrv.net/gimg/www.aud...e5b9941a0e.png |
Very Nice! are you willing to sell your OEM navigation?
This post was immensely helpful. Thanks for this. Looking at Car Play HU's to potentially swap in to my '13 TTRS so this will be at the top of the list given that I can basically print this out, give it to the install shop and let them go to town.
Thanks again. |
Does your Sirius XM tuner still work? Do you know if you can still use the stock Audi Sirius tuner and 6-disc CD changer?
Thinking of doing this to a 2009 TTS that currently has RNS-E... |
Thanks for the detailed installation. Folks keep telling me that speaker swaps are the way to go for sound improvement. But sounds like just the unit did you right as far as sound.
I'm not looking at this unit but a 699 buck Alpine. I wonder if it would improve sound as well, not to mention the interface. |
Originally Posted by reedog117
(Post 24650147)
I'm very interested in adding this unit to my 2009 TTS as well. My car only has the basic head unit not the RNS-E.
Any help figuring out what parts I would need to get this to work would be greatly appreciated!!! |
Originally Posted by RaiderTT2001
(Post 24654397)
Any way to use the stock microphones? I don't like the idea of taking apart the headliner to add additional mics. Does the backup warning system still work when in reverse?
