SD Card won't read/play in TTS
I'm using a 2GB SanDisk SD card loaded from my iTunes library. When I put the card in my 2011 Q5, it reads and plays fine. When I put the same card in my 2011 TTS, it says "unknown files found", and won't play. Am I doing something wrong, or do I need a better quality SD card for the TTS?
The manuals for both cars say to use a Grade 4 or better, but if it plays in one, it should play in the other? |
In my experience, the TTS will only play plain SD memory cards. Have you checked to make sure it is not a SDHC card? I could not get these to work either.
Mike |
Thanks, Mike. I thought I had that covered per the manual, but I'll check again.
Originally Posted by S4Q04
(Post 24063651)
I also have the same situation with my 2009 3.2 ...SDHC will not play nor will SD cards larger than 2.0 |
Originally Posted by Mike
(Post 24064690)
BosTTon |
