TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
Thinking of buying 2014 TTs
Old 10-17-2018, 12:33 PM
Default Thinking of buying 2014 TTs
Hey guys, Im totally new here.
was hoping for some hospitality and new stuff to learn i guess.
Any opinions or common things to look out for problem wise with 2014 model?
The car has 55,000kms on it, and with a meh car proof/fax
a crack underside on the sheathed body,
missing sparetire and jack,
shop said misfire code was in it cleared
suggest replacing spark plugs ( i think thats the misfire?, idk?)
also i was driving and low tire pressure error came on
the dealer stated new rear shocks, which they are replacing, but when i took it to a mechanic, they saw nothing with the shocks.
im left feeling a little uneasy
link is below
https://www.autotrader.ca/a/audi/tts..._13_13&sprx=-2
t00ki is offline
Old 10-17-2018, 01:51 PM
bump pls suggestion and opinions?
t00ki is offline
Old 10-17-2018, 05:10 PM
Read this FAQ https://forums.fourtitude.com/showth...-MK2-TT-a5-FAQ
Pay attention to the mag ride discussion in the FAQ which the TTS has. The Mk 2 did not come with a spare nor jack
Vegas-roadster is offline
Old 10-17-2018, 07:28 PM
Thank you very much! Im in canada also I forgot to mention
t00ki is offline
Old 10-18-2018, 04:33 AM
anyone else? any info? the car was sold at an auction, 1 owner, two dealerships with, a total of 3 owners, and currently back at a dealership
t00ki is offline
Old 11-02-2018, 12:37 PM
tropos's Avatar
What happened with this? Did you get it? My thoughts - 55K service mark is pretty much everything (https://www.audiusa.com/content/dam/...-Year-2014.pdf) so you could be in for a chunk of change right off the bat. Probably the reason for the misfire code is that it needs it's regular maintenance, including spark plugs.
The shock replacement recommendation is questionable...mine didn't need it until 75K miles, but maybe the roads are rougher there?
tropos is offline
Osmosis
11
05-17-2019 03:41 AM
in2audi
10
08-23-2018 12:32 PM
ebtahi98
09-29-2017 04:26 PM
Asphalt_MadMan
06-17-2013 05:24 AM
audiboi2
09-07-2009 05:00 AM
Quick Reply: Thinking of buying 2014 TTs
