Tire Pressure Monitoring System warning (false alarm?)
#11
"The valve stem caps and cores used are specifically designed for the TPMS..."
<center><img src="http://www.ttstuff.com/images/oem/OEMVSC-ASR_540.jpg"></center><p>Maybe it's the valve stem caps after all? Thankfully I didn't discard the black plastic ones yet, but they sure didn't look very special to me. If the error message re-appears tomorrow, I may swap back to the old valve stem caps to see if that makes a difference. The photo shows the new metal valve stem caps (which apparently look nicer but may cause problems with TPMS).
#13
Was it particularly cold ?
FIlled my winter tires when it was about 5C. Leaving the dealership after my 8000 km first service, the TPMS went off about a block away. Reset it and it was fine. Checked the tire pressures and they were a bit low. The -12C weather may have had something to do with that ?
#15
TPMS malfunction
2012 Audi A4 Quattro. Changed 1 of 4 tires because it was defective with same brand, size, treadwear but slightly different model. Checked air pressure in all tires and reset TPMS system accordingly. TPMS malfunction displays after 20 minutes?
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
mkirkpatrick
Wheels & Tires Discussion
09-03-2015 08:31 AM
stormchaser1967
09-02-2015 09:26 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
