TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
VagCom analysis?
Old Jul 9, 2011 | 03:58 AM
GaBoYnFla's Avatar
Default VagCom analysis?
Anyone have ideas as to what happened to my TTS....mis-fires?
Friday,08,July,2011,20:10:50:15500
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Address 01: Engine Labels: 06F-907-115-CDL.clb
Control Module Part Number: 8J0 907 115 BA HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 02 0020
Software Coding: 0113010A1C0F0160
Work Shop Code: WSC 01236 785 00200
VCID: 6CDC42FE361B
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 5146 km
Time Indication: 0
Date: 2011.07.06
Time: 08:14:58
Freeze Frame:
RPM: 5754 /min
Load: 68.2 %
Speed: 74.0 km/h
Temperature: 84.0°C
Temperature: 36.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000772 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 5146 km
Time Indication: 0
Date: 2011.07.06
Time: 08:14:58
Freeze Frame:
RPM: 5754 /min
Load: 68.2 %
Speed: 74.0 km/h
Temperature: 84.0°C
Temperature: 36.0°C
Voltage: 14.097 V
Readiness: 0000 0000
Old Jul 9, 2011 | 07:40 AM
Regina_TTS/Q5's Avatar
Tough call. Myself and a few others had the wrong exhaust valve springs installed in our TTS from the factory. I didn't noticed the misfires until I had the car flashed by APR. The new software seemed to make the misfires more obvious, but wasn't directly contributing to the misfiring. There's a few threads around on the issue and at least 5 other owners that I know of.
Old Jul 9, 2011 | 06:50 PM
GaBoYnFla's Avatar
Did Audi warranty the repair? Even with the APR? How is the APR btw? What program do you have?
Old Jul 9, 2011 | 06:59 PM
Audi covered the repairs under warranty for all of us as far as I know. My dealer knew that my car had the APR software. They are good about not pointing the finger at the modification.
The link in my signature shows you the difference in the power rating. It's stage 2 (software and down pipe) and it's outstanding. Such a quick car now.
rossej
9
Oct 13, 2013 12:08 AM
AmoKK
VAG-COM Discussion
Oct 1, 2009 04:11 AM
DM-S4
20
May 30, 2007 11:46 AM
Redgoat
Sep 29, 2005 05:13 PM
Redgoat
VAG-COM Discussion
Sep 29, 2005 08:50 AM
