Best wheel size for MK3 TT?
#23
19x8.5 ET45 Rotiform KPS’s for my daily wheels, 245/35 PSS’s. 15mm spacers in front, less than 3mm clearance from the calipers. 12.5mm spacers for the rears.
I’m going to try 245/40 PS4’s for the tires, since it’s my daily I need a little softer ride for the roads in town.
Keeping the 20’s and swapping for any planned drives.
#24
15mm spacers (~.6 inch)? That would certainly drive me to another wheel selection. Shouldn't have to alter the suspension/performance geometry to that extent unless aesthetics is the sole determinant.
#25
Wheel offset for 8J version will it fit?
Looking to buy a set from ABT 20 inch 9J with ET 40
stock is 18 inch and ET 52
will the 20 set fit on a normal TT?
( Not a TTS or TTRS)
thanks!
thanks!
A6S4 (10-22-2022)
#27
Offset différence
Hi thank you
weird thing is that if I lookup in wheelstores
it states that for the 8J you can go up till 19
and for the 8S till 20 inch??!!
8S has a oem ET 42 for the 20 inch
and 8J has a oem Et 52
but the difference between ET 40 and 52 is pretty big…
Will I need to do a new alignement?
#30
the offset for 9Jx20 OEM rim is 52, not 42
no wheel alignement needed, if you just swap wheels
Hi thank you
